.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message .. _install_other_os: Install Ubuntu / Kali Linux / RetroPie ============================================== This section guides you through installing **Ubuntu, Kali Linux, or RetroPie** on your Raspberry Pi using Raspberry Pi Imager. Required Components ------------------------------ * A computer (Windows, macOS, or Linux) * A microSD card (16GB or larger; recommended: SanDisk, Samsung) * A microSD card reader Supported Operating Systems ------------------------------- .. warning:: * This guide applies only to the operating systems listed below. * If you use a different OS version, the 3.5'' IPS screen may NOT work properly after installing the driver. * **Ubuntu** - |link_ubuntu_2404| (Raspberry Pi 4 only) * **Kali Linux** - |link_kali_202503| * **RetroPie** - |link_retropie| (Raspberry Pi 4 only) ------------------- 1. Install Raspberry Pi Imager ------------------------------------------- #. Visit the official Raspberry Pi Imager download page: |link_rpi_imager| and download the version for your operating system. .. image:: img/imager_download.png :width: 70% #. Follow the installation instructions (language, installation path, confirmation). After installation, launch **Raspberry Pi Imager**. .. image:: img/imager_install.png :width: 90% -------------------------------------- 2. Flash the OS to the microSD Card ------------------------------------------------ #. Insert the microSD card into your computer using a card reader. Back up any important data before proceeding. .. image:: img/insert_sd.png :width: 90% #. Open Raspberry Pi Imager and select your device (e.g., Raspberry Pi 5 or Raspberry Pi 4). .. image:: img/imager_device.png :width: 90% #. Click **OS**: * Scroll to the bottom and select **Use Custom**. .. image:: img/imager_use_custom.png :width: 90% * Navigate to the folder where you downloaded the OS image, then select the image file. .. image:: img/imager_custom_os.png :width: 90% #. In the **Storage** section, select your microSD card. .. image:: img/imager_storage.png :width: 90% #. Review all settings and click **WRITE**. .. image:: img/imager_writing_ubuntu.png :width: 90% #. If the card already contains data, Raspberry Pi Imager will display a warning that all data will be erased. Confirm that you selected the correct drive, then click **I UNDERSTAND, ERASE AND WRITE**. .. image:: img/imager_erase.png :width: 90% #. Wait for the writing and verification process to complete. When finished, you will see **Write complete!** The storage device will be safely ejected automatically. .. image:: img/imager_finish_ubuntu.png :width: 90% #. Remove the microSD card and insert it into your Raspberry Pi. Your Raspberry Pi is now ready to boot with the new operating system. .. image:: img/os_sd_to_pi.jpg :width: 70%
