.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message .. _install_os: 2. Install the Operating System =========================================== This section guides you through installing a compatible operating system on your Raspberry Pi. Different systems are supported depending on your Raspberry Pi model and use case. .. note:: Currently, the 3.5-inch display is only compatible with Raspberry Pi 4 and Raspberry Pi 5. For Raspberry Pi 3B, 3B+, and Zero 2W, it is not recommended to use them with the 3.5-inch display, as installing the touchscreen driver may cause it to malfunction. * For **Raspberry Pi OS**: - Trixie Desktop (64-bit) (released: 2025-12-04) - Bookworm Desktop (64-bit) (released: 2025-11-24, 2025-05-13, 2025-05-06) After installing the driver on Bookworm, you need to run ``startx`` to enter the desktop environment. * For **Ubuntu**: - |link_ubuntu_2404| (Raspberry Pi 4 only) * For **Kali Linux**: - |link_kali_202503| * For **RetroPie**: - |link_retropie| (Raspberry Pi 4 only) .. toctree:: :maxdepth: 1 install_rpi_os install_other_os
