.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message .. _install_driver_rapios: Install 3.5'' IPS Screen Driver on Raspberry Pi OS ========================================================= This section explains how to install the 3.5'' IPS screen driver on **Raspberry Pi OS**. You can access your Raspberry Pi either with a monitor or via SSH (headless), and then install the driver to enable the screen. If You Have a Screen ------------------------- **Required Components** * Raspberry Pi * Official Power Supply * MicroSD Card * HDMI Cable (For Raspberry Pi 4/5, use **HDMI0**, the port nearest the power connector.) * Monitor * Keyboard and Mouse **Steps** #. Insert the microSD card into your Raspberry Pi. #. Connect the keyboard, mouse, and monitor. #. Power on your Raspberry Pi. #. After booting, the Raspberry Pi OS desktop will appear. .. image:: img/connect_all_rpios.jpg :width: 90% #. Open a **Terminal** to enter commands. .. image:: img/open_terminal.png :width: 80% :align: center If You Have No Screen (Headless) ---------------------------------- Without a monitor, you can configure and log in to your Raspberry Pi remotely. This is the most convenient method for most users. **Required Components** * Raspberry Pi * Official Power Supply * MicroSD Card * A computer on the same network **Tips** * Make sure you have completed all settings described in :ref:`imager_custom` when installing the system with Raspberry Pi Imager. * Ensure that your Raspberry Pi and your computer are on the same local network. * For best stability, use Ethernet if available. **Connect via SSH** #. Open a terminal on your computer (Windows: **PowerShell**; macOS/Linux: **Terminal**) and connect to your Raspberry Pi: .. code-block:: bash ssh @.local # Example: ssh daisy@pi.local 2. Alternatively, locate your Pi’s IP address from your router’s DHCP list and connect with: .. code-block:: bash ssh @ # Example: ssh daisy@192.168.1.42 3. On first login, type ``yes`` to confirm the SSH certificate. 4. Enter the password you configured in Raspberry Pi Imager. (Nothing appears while typing—this is normal.) 5. After login, you now have full command-line access. .. image:: img/ssh_login.png :align: center -------------------------------------- Graphical Remote Access (Optional) ---------------------------------------- If you prefer a graphical interface: .. image:: img/desktop_trixie.png :align: center * :ref:`remote_desktop` — Use **VNC** for full desktop access * |link_rpi_connect| — Use **Raspberry Pi Connect** via browser -------------------------------------- Install 3.5'' IPS Screen Driver (Important) -------------------------------------------------- This is the key step to enable the 3.5'' IPS screen. Run the following commands: .. code-block:: shell sudo rm -rf LCD-show git clone https://github.com/sunfounder/LCD-show.git chmod -R 755 LCD-show cd LCD-show/ sudo ./MHS35IPS-show After installation: * Disconnect the HDMI monitor. * After rebooting, the system will be displayed on the 3.5'' IPS screen. Rotate the Display ----------------------------- You can rotate the display and touch orientation by running: .. code-block:: shell cd LCD-show/ sudo ./rotate.sh 90 The system will reboot automatically. After restart, the screen and touch orientation will be rotated to **90°**. You can replace ``90`` with ``0``, ``180``, or ``270`` to set the desired rotation.
