.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message .. _remote_desktop: Remote Desktop Access for Raspberry Pi ================================================== For those preferring a graphical user interface (GUI) over command-line access, the Raspberry Pi supports remote desktop functionality. This guide will walk you through setting up and using VNC (Virtual Network Computing) for remote access. We recommend using `VNC® Viewer `_ for this purpose. **Enabling VNC Service on Raspberry Pi** VNC service comes pre-installed in the Raspberry Pi OS but is disabled by default. Follow these steps to enable it: #. Enter the following command in the Raspberry Pi terminal: .. raw:: html .. code-block:: sudo raspi-config #. Navigate to **Interfacing Options** using the down arrow key, then press **Enter**. .. image:: img/config_interface.png :align: center #. Select **VNC** from the options. .. image:: img/vnc.png :align: center #. Use the arrow keys to choose **** -> **** -> **** and finalize the VNC service activation. .. image:: img/vnc_yes.png :align: center **Logging in via VNC Viewer** #. Download and install `VNC Viewer `_ on your personal computer. #. Once installed, launch VNC Viewer. Enter the hostname or IP address of your Raspberry Pi and press Enter. .. image:: img/vnc_viewer1.png :align: center #. When prompted, enter your Raspberry Pi's username and password, then click **OK**. .. image:: img/vnc_viewer2.png :align: center #. After a few seconds, the Raspberry Pi OS desktop will be displayed. Now you can open the Terminal to start entering commands. .. image:: img/bookwarm.png :align: center
