Install Virtual KeyboardΒΆ
When you use a touch panel, you can connect an external keyboard to help you do a text input operation, but it is best to install a virtual keyboard.
Install the required software with the following command.
sudo apt install onboard -y
sudo apt install at-spi2-core
In order to make the virtual keyboard have a better effect, you need to do further settings.
Click the Raspberry Pi icon in the upper left corner and select Preferences -> Onboard Settings.
_images/onboard.png
In the General option, check the following 2 items. When you check Automatically display when editing text, you will be prompted to reboot, you can reboot after all settings are complete.
_images/keyboard1.png
In the Window option, check Dock to screen edge.
_images/keyboard2.png
And in Auto-show option, check Auto-show when editing text again.
_images/keyboard3.png
The next 2 items are optional, the ones checked in the picture are recommended by us, you can also check other ones.
In Layout option, Small is recommanded.
_images/keyboard4.png
In Theme option, DarkRoom is recommanded.
_images/keyboard5.png
After the setting is complete, restart the Raspberry Pi. Every time you restart this screen, you need to click General Access -> Onboard to enable the virtual keyboard.
_images/enable_onboard.png
Now you can use this keyboard to edit your files or codes.
_images/keyboard6.png
