Create Musical Instrument
You can turn this screen into a game screen playing with your friends, a smart alarm showing the weather and time, a display monitoring your robot’s action and many other things.
This article will show you how to DIY a Musical Instrument. Let’s take a look!
_images/paino1.jpg
  • A Screen
  • 8G+ SD Card
  • Scratch 3 (either online or offline)
  • Micro SD Card Reader
  • 40 Pin Ribbon Cable
  • T-Type GPIO Extension Board
  • Breadboard
  • Button
  • 10k Ohm Resistor
  • Several Jumper Wires
You Will Learn
  • Use note functions on Scratch.
  • Input the button value from the GPIO pins.
Lesson Guide
Build the Circuit
First connect the GPIO Extension Board, please read GPIO Extension Board for specific steps.
Insert the T-type GPIO extension board into the breadboard and build the circuit as shown below.
_images/paino3.png
Programming with Scratch 3
On the left of Scratch 3 main page are some neatly arranged blocks with which you can drag to program. In this project, we need to add in other two functions: Music and Raspberry Pi GPIO. The Music function to play instruments and drums, and the Raspberry Pi GPIO function can be used to control the whole pins of Raspberry Pi.
_images/paino5.jpg
Tap Add icon at lower left corner and choose Music and Raspberry Pi GPIO to add two functions on the left of the main page of the Scratch 3.
_images/paino6.jpg
Finished the program.
_images/paino7.jpg
Press these three buttons on the breadboard and there emits the tones “Do, Re, Mi”.
_images/paino8.jpg
