3D Printer Monitor
When using a 3D printer, we will need to use OctoPrint. It is an open source 3D printer controller application, which provides a web interface for the connected printers. It displays printers’ status and key parameters and allows user to schedule prints and remotely control the printer.
Please refer to the detailed installation tutorial for OctoPrint: https://community.octoprint.org/t/setting-up-octoprint-on-a-raspberry-pi-running-raspbian-or-raspberry-pi-os/2337.
This tutorial has written very detailed installation steps, which may take a long time and requires more patience.
  • The Raspberry Pi Operating System will need to be installed on the micro-SD card before starting the tutorial. Please refer to INSTALL THE RASPBERRY PI OS.
  • Webcam Option: A camera will need to be installed on this screen for webcam use. Please refer to the tutorial: Assemble the Camera Module.
  • Touch UI Option: A new Raspberry Pi image might not have an auto start function for Touch UI. Please refer to the tutorial: Touch UI to configure the settings for the Touch UI function.
Touch UI
If the autostart file is not located in the ~/.config/lxsession/LXDE-pi path, the file will need to be added manually.
Create the lxsession folder and the LXDE-pi folder in the ~/config directory.
mkdir ~/.config/lxsession
mkdir ~/.config/lxsession/LXDE-pi
Copy the autostart file from the path /etc/xdg/lxsession/LXDE-pi to the ~/.config/lxsession/LXDE-pi folder.
cp /etc/xdg/lxsession/LXDE-pi/autostart ~/.config/lxsession/LXDE-pi/autostart
Set the permissions of the autostart file to be readable and writable.
chmod 644 ~/.config/lxsession/LXDE-pi/autostart
nano .config/lxsession/LXDE-pi/autostart
Open the autostart file with a text editor such as Nano, and add the following line to the end of the file to make the Raspberry Pi execute the startTouchUI.sh script file on boot.
@/home/pi/startTouchUI.sh
After restarting the Raspberry Pi, the OctoPrint’s Touch UI will open in full screen mode. Press F11 to exit the full screen mode and enter the desktop.
Make a 3D Model
Click this link: https://projects.raspberrypi.org/en/projects?hardware%5B%5D=3d-printer, refer to the official Raspberry Pi tutorial, you can get the 3D model file in the format of .stl.
Generally, 3D printers cannot directly process .stl files. You need to use Ultimaker Cura software to slice them, and then upload them to the 3D printer through OctoPrint to print the 3D model file.
Download Ultimaker Cura. Since Ultimaker Cura is not available on the Raspberry Pi system, you need to perform the slicing operation on your computer.
_images/oct2.png
Select the version you need.
_images/oct3.png
When installing Ultimaker Cura, please note that in the choose components step, Open STL files with Cura has been checked by default, so that .stl files can be sliced.
If you want to slice other types of model files, check the corresponding option, otherwise you can install it directly.
_images/oct4.png
When opening Ultimaker Cura for the first time, there will be a series of configuration prompts. At the Add a Printer step, select the model of printer used and click Next.
_images/oct5.png
After selecting the correct printer model, verify that the parameters provided by Ultimaker Cura in the Machine Settings page are correct, or change the parameters directly.
Follow the onscreen prompts to complete the configuration of Ultimaker Cura.
_images/oct6.png
Once Ultimaker Cura has successfully launched, click the Folder icon in the upper left-hand corner and browse to the folder with the .stl 3D model file that needs to be sliced, and click Open to add the .stl file to Ultimaker Cura’s library.
_images/oct7.png
After the file has been added, click the Slice option in the lower right-hand corner, and Ultimaker Cura will automatically perform the slicing operation.
_images/oct8.png
After slicing is complete, click the Save to Disk option in the lower right corner to save the sliced ​​file locally.
_images/oct9.png
Select the type of file extension recognized by the 3D printer, then click Save.
_images/oct10.png
Video
The following video shows that after installing OctoPrint, connect your 3D printer and this screen through a USB cable,upload the designed 3D file, and then use the camera to monitor the printing process.
The temperature can also be monitored to prevent the 3D printer from getting too hot or cold, which will affect the printed 3D model.
